PSA : Cheap New Replacement FOBs
Old 03-30-2021, 03:57 PM
Andre Reichert-Creutz's Avatar
Wow, exactly what I'm looking for. The original remote control of my X308 from 1998 is defective and cannot be revived. It's a LJA2610BA
Unfortunately, the eBay links for ordering no longer work. Do any of you have an address for me? That would be great
André
  #42
Old 03-30-2021, 08:00 PM
Highhorse's Avatar
Received 1,797 Likes on 1,319 Posts
The second one is a repair service in the UK... https://www.ebay.com/sch/i.html?_fro...y+fob&_sacat=0
....https://www.ebay.com/sch/i.html?_fro...r+x308+key+fob
....use the part # off your fob, it will help dial in your search. The part # is important since its set to a frequency.
  #43
Old 10-09-2021, 01:13 PM
Dickiederson's Avatar
Originally Posted by King Charles
So I bit the bullet & gave this vendor a whirl, it programmed 1st attempt & included the battery already installed. It also has a smaller footprint for less bulk in the pocket, I deem this a win for sub $50.
https://www.ebay.com/itm/For-1998-19...5/352437842314
I
i was so excited when I saw this but it looks like he no longer sells them… 😖
  #44
Old 08-23-2022, 02:14 PM
Noah's Avatar
Hello, I'm reviving an old thread here to ask if anyone has recent success using an aftermarket fob to replace their non-working Jaguar fob in the US? The ebay links in the thread no longer take you to an active listing or help identify the vendor. This is for a 2002 XJ8/Super V8 in the USA market. The back of mine reads LJE2610AB - CWTWB1U322 - CAN 1788 102 354.
A search for CWTWB1U222 or LJE2610AB on ebay or google pulls up some cheap options like the link below but when you look at each listing for compatibility it actually says it's not compatible with Jaguar. Or the search brings up used Jaguar fobs which may be an option I'll explore. Or does anyone know of a company offering fob repair in the US? My car came with 2 fobs and 4 tibbe keys. One fob works some of the functions and the 2nd one doesn't work at all even with fresh batteries. Thanks for any input. Cheers.
https://www.ebay.com/itm/29304520446...3ABFBM2p7bwNlg
  #45
Old 08-23-2022, 09:10 PM
Highhorse's Avatar
Are you using (2) 2016 batteries or (1) 2032? Review this if your using 2016's....https://www.jaguarforums.com/forum/x...pgrade-210090/
  #46
Old 08-24-2022, 03:08 AM
RandyS's Avatar
Yes indeed, a 2032 works far better than doubled 2016s. and seems to cause no ill effects.
  #47
Old 08-24-2022, 07:25 AM
xalty's Avatar
Received 1,060 Likes on 851 Posts
2001 and later is ford 4 button
before is the special remote
can’t find super special remote? change the slm to a newer one
  #48
Old 08-24-2022, 08:36 AM
RandyS's Avatar
  #49
Noah's Avatar
Thanks for the responses. I'm using a single 2032 battery.
@xalty, thanks, I'll try one of those Ford 4 button remotes for my 2002. Do you know if I would need to program my existing remote (the one that works for some functions) at the same time I'm programming the Ford 4 button one?
  #50
Old 08-25-2022, 12:40 PM
vincent661983's Avatar
Originally Posted by RandyS
You can find the original style fob for as little as $25.
GENUINE OEM JAGUAR KEYLESS REMOTE REMOTE CONTROL FOB CWTWB1U322 XR83-15K601-AA | eBay
but this one only works with post 2000 model year X308s
Noah (08-29-2022)
  #51
Old 08-25-2022, 02:35 PM
leaddog11's Avatar
Interesting discussion
if your programing 3 how many times then to press the buttons each?
  #52
Old 08-25-2022, 02:49 PM
Received 8,134 Likes on 4,908 Posts
The same remotes will work for the 4.0 X100 coupe/conv Jaguars.
Same FOBs for the MY as the X308.
  #53
Old 08-27-2022, 11:47 AM
David N. Warner's Avatar
The XJR I bought recently had this same aftermarket key FOB and it works just fine; better than the original one. It has a 2032 battery inside
Aftermarket FOB.
Noah (08-29-2022)
GordoCatCar
07-29-2024 11:00 AM
Highhorse
10-21-2019 12:11 PM
redxk8
09-30-2015 08:18 AM
marktmv
11-02-2008 08:02 PM
smileboot
04-27-2007 11:05 PM
Quick Reply: PSA : Cheap New Replacement FOBs
