Q: AJ27/SC - oil pressure/boost sender tees
Where could someone tee into lines or ports for aftermarket oil pressure and vacuum/boost gauges?
The usual candidate for oil pressure is to tee the factory oil pressure sender. Suggestions of secondary locations would be nice.
Then there is the vacuum/boost gauge. It has to see the pressure downstream from the supercharger. Is there a port somewhere?
If anyone knows the thread sizes of the ports, that would really cut down on the "remove, take a look, put it back, drive to parts store" routine.
The three selected gauges are:
voltmeter
oil pressure
vacuum/boost combo
Real needles please. No interest in siphoning data from the ECU whatsoever.
voltmeter
oil pressure
vacuum/boost combo
The supercharger outlet (that has the "V8" on it) has a outlet on the right hand side, that is used for the fuel pressure regulator, you can tap in here.
plums (04-05-2011)
Woznaldo
09-26-2015 11:02 AM
