Q: AJ27/SC - oil pressure/boost sender tees
Old 04-03-2011, 07:49 PM
plums's Avatar
Received 2,184 Likes on 1,624 Posts
Default Q: AJ27/SC - oil pressure/boost sender tees
reposted from:
https://www.jaguarforums.com/forum/g...er-tees-52435/
Where could someone tee into lines or ports for aftermarket oil pressure and vacuum/boost gauges?
The usual candidate for oil pressure is to tee the factory oil pressure sender. Suggestions of secondary locations would be nice.
Then there is the vacuum/boost gauge. It has to see the pressure downstream from the supercharger. Is there a port somewhere?
If anyone knows the thread sizes of the ports, that would really cut down on the "remove, take a look, put it back, drive to parts store" routine.
The three selected gauges are:
voltmeter
oil pressure
vacuum/boost combo
Real needles please. No interest in siphoning data from the ECU whatsoever.
Old 04-04-2011, 09:14 AM
Sean B's Avatar
Received 1,366 Likes on 1,074 Posts
these add-ons are something I'd suspect the S Type R, XKR crowd would install. Maybe post in the general/engines or S and XK forums?
Old 04-04-2011, 11:24 PM
plums's Avatar
Already tried "general technical help", a couple of bumps, and a plea to a particular member.
The boost sensing is the most problematic.
Searching on "boost gauge" only yields a few threads, with one old post claiming tying into the fuel pressure port? HUH?
The oil pressure is less problematic. Just looking for alternate locations aside from teeing the stock oil pressure sender port.
Old 04-05-2011, 03:51 AM
Count Iblis's Avatar
The vacuum/pressure for the fuel pressure port DOES make sense though. T off from there. It's taken off the central plenum that says "V8" on it- there's a very small 1/4 inch hose/port to the left (when viewing engine from the front).
At Jaguar we would drill and tap our own ports- that's what I do with my own project cars also.
You take your choice.
The following 2 users liked this post by Count Iblis:
Panthro (04-20-2012), plums (04-05-2011)
Old 04-05-2011, 05:28 AM
plums's Avatar
Thumbs up
Thank you again for this and your answer in the other post.
The tee will be fine, given that the cleaner approach of drilling & tapping is ideally done with the parts off the engine.
bdboyle
09-16-2019 05:58 PM
kthrash
02-25-2019 10:20 AM
JCam
10-23-2016 08:27 PM
Woznaldo
09-26-2015 11:02 AM
ahunt4
09-25-2015 03:43 AM
Quick Reply: Q: AJ27/SC - oil pressure/boost sender tees
