Question about acs/trac control
When i first got my 02 VDP i had the acs/trac not available light on in the dash. I had the bushings, new ball joint, and the sensors cleaned and it went right away. This was about 5k miles ago.
Today I took a turn way too fast to test out my new tires grip and i did hit a small bump..nothing big..and immediately i had a acs light come on in the dash and it was like the accelerator wouldnt work. As soon as I got through the turn the light went off and accelerator went back to normal. I drove another 3 miles and turned the car off to go to the post office.
Upon exiting the post office I restarted the car and had the acs/trac not available lights on and braking sucked. Drove to my next stop and after restarting the car again I only had the abs light on. I drove home and halfway there the abs light went off and all is back to normal.
Any ideas on what happened or if I have a problem creeping up? thanks
Guest
Posts: n/a
I had a similar experience last year. I bought my XK8 last May. I had the Stability Control / Traction control warning on my digital warning display. Appeared for 2 days. Booked an appointment with my friend at Nene Jag in Peterborough but on the day I drove to them the warning had gone out. The diagnostic displayed showed that the error had occured but without the warning/error being displayed Clive couldn't do anymore than tell me that the error had been registered on the ECU. About 2 weeks passed the error re appeared and I immediately took it again to Nene Jag. Clive recommended either to recon my existing Stability Control/ Traction Control ECU Unit cost Around £400 or replace with a new one for around £1000. Clive said that he had sent ECU's away a few times and he'd never had any come backs once the ECU had been sorted out. Luckily for me my car was under warranty and I had the job carried out by Claridges Cars the dealer where I purchased my XK from. Not had any issues since. Nene Jag are a specialist based in Peterborough Cambridgeshire. Highly recommend them. Always worth a call.
Does traction control actually work on ice & snow? Although we bought ours in January, we had no snow this year. I'm a bit leery about how much traction control is going to help fix the 290HP RWD problem. My current plan is to make sure the Jag is parked in the garage if there's even a chance of snow, but it would be nice to know it could handle an inch or two if I were to get caught at work...
And, as far as how it works in the snow? Awesome! I took a drive over the Sierra's last week, and ran into about 4 inches of snow on the ground. Here in California, that means chains! Not wanting to spend the $94 for chains because I don't carry them and didn't buy them down the hill, and not wanting chains on my car, I fibbed when asked if I had all wheel drive at the check point. He looked inside, at which point I pointed to the Trac Off button, and he let me proceed.
I messed around a bit, just to give myself a little peace of mind, and to my surprise, the car did incredibly well. I've got brand new Goodyear GT's on it, but any time I started to get a little loose, or sideways, (on purpose), the Trac Control kept me going straight and even. The moment I took it off, it was like Ice Skating using a Snow Board. Nearly zero control, due to the wide tires. I've drivin in the snow my whole life, so I'm VERY comfortable being sideways, but it was nice seeing the system work as well as it did.
It works great in the snow-During Britains "Big Freeze" this year I drove my XJ all over, and it woked great. I felt quite smug crusing through the snow covered streets and lanes in the big cat. Why Smug? Because at the time the streets had been turned into a BMW, Mercedes and Lexus Grave Yard. Even saw a couple of X5s and M classes abandoned.
You can guess all day about ABS modules and other faults but you won't know anything until the modules are scanned for DTCs. There are some common probs with the ABS (module solder joints, front wheel speed link harnesses etc.) but why guess when the modules probably will tell you why they are flagging faults????
bob gauff
bob gauff
thanks motorcarman i did not know you can scan the modules. I take it you have to have a dealer scan those codes correct?
there is a ebay seller with great feedback that repairs your abs module for 50-150 bucks and they pay shipping both ways..i was thinking of going that route, but it is probably smarter to get it scanned for codes first.
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
abonano
25
09-25-2015 10:43 AM
James007
09-06-2015 06:47 PM
