Quick abs question
pingj (08-15-2014)
I've already pulled the module once and did the solder repair. That was a little over a year ago. No problems for over 6 months then I would get intermittent ABS light with the ASC/TRAC not available.
Almost seems to be heat related. For instance, this morning when I left for work no light. Temp was mid 70's. This afternoon when leaving work, temp 95+ immediate light upon starting.
Either way I'm pulling the module this weekend. I'm going to a junk yard tomorrow to get some other parts and was going to get a module too, but since the numbers have to match I doubt I will have much luck.
The yard has several XJ8's but I'm still not very hopeful.
What DTCs are logged in the module????
What if you replace the module and the fault returns????
What if a sensor or harness is at fault and you just keep replacing the module?????????
Are you diagnosing or throwing parts at you problem??
There are 5 different ABS modules for the X100/X308 cars.
Some are the same for both the sedan and the XK.
There is only one module for the later X308 and X100 (JLM21323) 9 valve (blue colored)-6 pipe, but I forget the VIN split. It is in the JEPC and the numbers on the module are NOT the actual part number that Jaguar uses.
bob gauff
bob gauff
RJ237 (08-16-2014)
innzane
09-02-2015 10:08 AM
