Quick Head Bolt Question
Hi Folks,
I'm getting ready to reassemble the engine and, obviously, need to replace the head bolts. I understood that the Land Rover bolts are cheaper and looked into them. I found part number 4677857G for all 4.2, 4.4 and 5.0 Jaguar engines. At $35.xx for a set of 10 for 1 head I was pretty pleased. Now for the question: The illustration shows these bolts to be allen head instead of the hex heads that came out of my engine. Is this what I should expect and is there any concern switching to allen head over hex?
If that isn't the right part number, I'd sure appreciate a little guidance into the right one.
Thanks for any help....
BW_Hunter (01-22-2014)
Jaguar did issue a TSB and Mandatory Special Tool 303-1077 RIBE bit for the cam sprockets.
There is a difference between RIBE and TORX. They are both 6 point but the similarity ends there.
I don't know if the head bolts are RIBE or TORX but Jaguar has issued this tool.
BMW uses TORX on some heads.
VW/Audi uses RIBE on some heads.
Just thought I would mention this and see if anyone knows what Jag is using.
bob gauff
bob gauff
dsetter (05-25-2016)
al_roethlisberger
09-11-2015 10:04 PM
Tar
09-06-2015 11:24 AM
philwarner
09-05-2015 10:05 AM
