Quick question- what is the generic equivalent for jlm11965 bulb, climate control lcd
I can only find jaguar oem numbers for the climate control backlights. Can’t find a cross reference online, also saw grain of wheat bulb listed, but they come in different sizes like t3, t3.2, t4 etc. just seems to be a general term for tiny bulb lol.
i know it’s smaller than t5. Also looks like it will have to have a plastic twist base. I’m sure people have switched these to led, but I only see the jaguar part listed. I’d rather not spend $10 each for a tiny bulb when I can get 20 for $3 from China lol.
I don’t mind if I have to whittle the base a little to fit. I had to do that with the clock bulb. After I get the climate control bulbs changed, I’ll finally have the all the burnt out bulbs done!
Thanks very much
Thanks very much
LED Interior Lights : The number on the far left is for pairs, so 2 ea. means 4 lights, so its double that number.
2 ea. T10 W5W Dome Style (White) – Pair doors
5 ea. T10 W5W Inverted Style (White) – Pair rear and map and boot
2 ea. T10 6-Chip SMD Style (White) – Pair speedo
1 ea. 36mm 2-LED SMD (White) - Pair rear number plate
2 ea. 10mm/T4 Neo Wedge (Blue) – Pair heater screen dip and trip
2 ea. 8mm/T3 Neo Wedge (White) – Pair map and console
6 ea. 8mm/T3 Neo Wedge (Blue) – Pair console
1 ea. 8mm/T3 Neo Wedge (Green) – Pair console
2 ea. B8.7D Twist Lock 1-LED (White) – Pair speed
https://www.jaguarforums.com/forum/x...n-xj-v8-34491/
jag_guy_2020
08-16-2014 06:17 AM
domer94
12-30-2011 09:31 AM
