So I'm putting my valve covers back on my car and I seem to be missing the two bolts that go in the center of the vavle cover in the middle of where the coil packs sit (I've circled it in green in the pics below)
I got the photos below from some ones timing chain replacement walk through and I can't quite tell but it looks like there bolts go in a sleeve like all the bolts around the edge of the valve cover.
My question is this, do I need to order these sleeves or is this just a simple bolt and a flat washer.
Ok so it is the same bolts and as the rest of the valve cover. I guess I'll borrow a few from around the edge of the valve cover and use those there so I'm not held up waiting for them to arrive. Thanks.
