R1
Meredith.marton (01-22-2017)
Slight mistake on Wikipedia, the "R1" package did not include a "re-tuned" suspension.
While it is true that the front hub carrier (vertical link) has a different part number for the "R1" package, it is in fact the exact same one than non R1 with the only "difference" being closer tolerance on the drilling/tapping for the caliper mounting holes
Reason being the the brembo are fixed calipers compared to the normal floating ones
That by itself do not qualify as "re-tuned" suspension
As for the US, quite a few cars, especially in 02 and 03 came from England with the R1 package so it was not really a dealer option save for the fact that dealer had "R" with and without the R1 package
I will venture that no R1 package came to the US in 98 and 99, a few in 00 and 01 and quite a lot in 02 and 03
BTW, very few people know that they were really 2 choice of colors for the Milan wheels, Oyster and silver.
all the brochure and advertising in the US show the oyster only.
But I don't remember seeing any R1 with the silver wheel at the various jaguar dealership.
I retrofitted the R1 package, with silver Milan, on my 01 XJR and it was quite a process, mostly due to the fact that the dealers insisted that i had to change my front hub carriers/vertical links, which is BS, even if they have a different part #
Ok here goes...this should put to rest any questions about the XJR "R1" package....
In late 2001 when Ford had controlling interest in Jaguar
The XJR model became available with a "R" performance package...this package was only available in the USA as EPA regulations prevented this in other areas of the world..also Ford is an American company so obviously...blah blah blah...the package has as follows...Mercedes 5gtronic transmission...stainless exhaust system...reprogrammed ECU and transmission
Retuned suspension.."stiffer"...brembo brakes and cross drilled rotors...BBS Milan wheels to clear the large brakes..."R" badging to indicate the package on 3 places on the car...the left and right fenders under the the jag emblem and the trunk under the jag emblem...a different shift knob....silver with gold "supercharged" decal..also this package was a dealer only option at the time..it is known as the "R1" because it was the first gen of the performance package with r2 r3 r4 etc. Being the subsequent package of the years following...the "R1" is a short lived package as the end of the production year soon followed and significant body redesigns were introduced the very next year...if there are any questions I will be happy to reply as I actually in real life own one..it is platinum silver and is fast as f** thank you for asking
The merc transmission is used on all supercharged x308's. Also, the EPA is a US agency, so it'd make it harder to bring uptuned cars into the states, not the other way around. Also, it doesn't make sense to start a new thread on the same topic as the thread you posted on r1 packages before this..
Received 13,090 Likes
Hi Meredith.Martin,
Welcome to the Jaguar Forums! It's great to have you with us.
I have merged your second thread with your first since they are on the same topic and keeping all the posts in the same thread helps avoid confusion and duplicate responses.
At your earliest opportunity, please visit the New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum and post a required introduction so we can learn something about you and your Jaguar and give you a proper welcome.
Cheers,
Don
Cheers,
Don
Let start from the beginning:
R1 was NOT a dealer option. Dealer option mean that it was an option installed by the dealer and the R1 was installed at the factory in England.
Here is an all inclusive list of what made the R1 option in the US
1/ Milan wheels
2/ Brembo calipers
3/ Larger, cross-drilled front and rear Brembo rotors
4/ Braided stainless steel brake lines
5/ Bigger front and rear brake dust shields
6/ Front up links with different part # because threaded holes instead of plain for caliper mounting bolts
7/ Different front calipers mounting bolts
Nothing else. I'm really curious where you got your info from?????
Z07Brandon (09-22-2019)
Someone stuck those "R" emblems on your car, that's not an "option" by any stretch. I had some guy selling his XJR here in Jax try to pass off his XJR with those things stuck on it as something "special" he finally fessed up he'd ordered them and slapped them on as he thought it looked cool. Daft is more like it. Here's a link with pictures of an actual "R1" equipped XJR, notice the absence of the "ebay" "R" badges. It also shows the option on the window sticker which is NOT dealer installed. Dealer install items use a supplemental decal http://www.mcsmk8.com/01-XJR/JAG.html.
Obviously, you having an R1, and as your posts show, do not make you an expert on those cars.
The giveaway was the description of a "different shift knob, silver with gold decal."
Its exactly the picture of the shifter than you have in your car
You got very lucky, you scored the only XJR R1 in the world with silver and gold shifter knob, 'R" decals on fender and trunk AND Enkei wheels
Congratulations
