Rack and Pinion
Rack and Pinion
Ok,
In other posts I have mentioned a moaning or creaking coming from the front end but only when turning the wheel to the left(not moving, stationary), two shops thought it was the outer tie rod, so I replaced both. However it is still there. One shop thinks it's the rack itself, but I would tend to believe it would make the noise turning left or right. Right?
I kind of thought it was a lower ball joint but those we're replace 8 months ago, albeit I believe with Üro units.
Ideas?
Thanks,
Chris
Ideas?
Thanks,
Chris
Always include year and model information with your post please. If it is an 98-02 X308 XJ, you hear it only to the left, only while driving, your answer is a dry bearing most likely. The sealed bearings on these models wont feel loose, but the will make a loud groan when turning. In all my years as a Jaguar mechanic, I have yet to change one of these racks for noise.
Chris
margate69 (06-19-2014)
No they were replaced due to some play in them.
Chris
Last edited by Badbenz94; 06-20-2014 at 06:18 AM. Reason: Using the correct "due" :)
Woznaldo
09-26-2015 11:02 AM
