radiator cooling fans
The following 2 users liked this post by test point:
Don B (08-10-2015),
Doug Dooren (08-06-2015)
The following 2 users liked this post by rocklandjag:
Don B (08-10-2015),
Mine has never run on after shutting down; but many others have. If you have a good OBDII reader, plug it in while it is running and observe the engine temp. If more than 205* or so with the fans running (and AC on) you may need to renew the TST, the coolant, and check the drive belt. Both fans should be running if it is still that hot.
Is it the original water pump?
I have had BMWs and Hondas that would run on for a minute -- it was considered normal: don't think so for these cars. Note well: (nb if you are into Latin) With 3 Land rovers and 3 Jags, I have never had an AJ 8 cylinder engine run on.
The following 2 users liked this post by Jhartz:
Don B (08-10-2015),
The following 2 users liked this post by RJ237:
Don B (08-10-2015),
The following 2 users liked this post by plums:
Don B (08-10-2015),
I guess Bob breaks the tie and it's not normal. Since first posting, the fans kept running on longer - got to the point I had to disconnect the battery after 5 minutes or so. Temp gauge always read normal until today when it spiked and the indicator light came on for about 20 seconds. Just as I was pulling over the light went out and the gauge dropped to normal. Checked the coolant level after the engine cooled and it was normal. Will replace the thermostat this weekend and refill and bleed. I'm assuming this simply involves bringing the engine up to operating temp and running with the pressure cap off? Thanks everyone for your feedback - it's appreciated.
For an effective one shot bleeding method on a XJR see the following post:
https://www.jaguarforums.com/forum/g...6/#post1281761
Don B (08-10-2015)
bydand
09-27-2015 12:00 PM
