Radiator Fan
The fan fuses are number 12 and 14 in the LH fender panel. The fans start in series, then switch to parallel, with relays in the fan control module which is located near the LH crush tube just rear of the radiator. If a fan is jammed, like a bad bearing, the fuses can blow since the series start feature will not work to lower the inrush current. Check the fuses, for free spinning of each fan, then the module relays.
