Radiator fan and radio connected?
I am more curious here than concerned. Recently, for the time since I own the car (2.5 years), I have experienced a phenomenon where radiator fan stays on for a few minutes after turn off engine (not really a surprise there) but while that happens the radio stays on / antenna up. Few minutes later, fan switches off, radio turns off / antenna goes down. Can't think of any rationale between the radiator fan and radio ? This has happened 3 times now in as many months (Yes, this is during the 3 TX months where outdoor temperature are 100 daytime). Thoughts?
The car will run the fan, even when switched off, if the sensors detect it's required. On hot days, it could happen for like 5 minutes when the car is shutoff.
Would be more curious why the radio is staying on. I wonder if the ignition switch thinks the key is still in the ignition? Do you have the seat/steering wheel assist turned on, where the seat moves back when you take the key out?
