Radiator Fan Running
I know it's not uncommon for rad fans to run after the car is driven and parked, but I had never noticed it on this model. It may run at high speed for a minute or for several minutes after a drive. Granted it may be 85 to 95 F here.
I also THINK I hear it running at high speed at idle or at low speeds with windows down.
I cant recall hearing this before. Normal? Temp gauge is shows normal temp.
All thoughts welcome.
LA
LA
With the temp gauge showing "normal", the engine temperature could be anywhere between 160F and about 230F. The gauge needle is electronically pegged in the middle position over this wide temperature range. The fact that you have the fans running at high speed means that the engine is running hot. If you are also losing coolant, it could mean cylinder head gasket(s), otherwise the first things to check are the thermostat and the water pump.
