Radiator O Ring
Old 05-29-2016, 01:16 AM
larney's Avatar
Default Radiator O Ring
Anyone know what the part number or size of the o ring for the plastic tube running into the top left(drivers) side of the radiator? Thanks.
Old 05-29-2016, 03:28 AM
greverrr's Avatar
I used one from this box when one of my small coolant line o-rings finally totally decayed. Don't recall which one exactly, but it fit and consequently works
225 Piece Nitrile O-Ring Assortment
and yes, nitrile is compatible with ethylene glycol
http://www.documentation.emersonproc...798x012_06.pdf
The following 2 users liked this post by greverrr:
Jhartz (05-29-2016), larney (05-29-2016)
Old 06-02-2016, 10:02 AM
larney's Avatar
I noticed Harbor freight had a box of assorted O Rings for automotive use. Would these work as well any reason to spend the extra 4 bucks?
180 Piece Viton O-Ring Kit
Old 06-02-2016, 07:55 PM
greverrr's Avatar
Viton is also safe with coolant
Viton Chemical Compatibility Results
larney (06-02-2016)
Old 06-02-2016, 10:03 PM
nilanium's Avatar
Is it for the s/c radiator or main radiator? I found these for the s/c rad when i was looking for a bleed hose recently, the main radiator may use different o-rings though.
Part no. KSR605001 | O-ring parts from Jaguar Classic Parts UK
EDIT: noticed you have an xj8. same still applies, I'm not sure if the O-ring i have here is the one you need.
larney (06-03-2016)
springer
04-22-2016 11:05 AM
CoventryFlagship
04-20-2016 05:52 PM
webbeing
04-18-2016 11:46 PM
jagtoes
04-15-2016 06:38 AM
silversurfer1221
04-06-2016 05:26 PM
Quick Reply: Radiator O Ring
