Radiator sealer any good ?
When I read your question, I remembered that Scotty Kilmer did make a clip about it:
I guess his answer is "maybe, but if you are not 100% that you do not have a blown head gasket, then don't."
I would not use sealer ever, because, if it does what it promises, then it seals, and most likely not only where you want it to seal, i.e. you could have adverse side effects, e.g. a stuck thermostat.
Alright What if I remove the thermostat then add the sealer?
park the car
glass block sealer is good for a pos with a slightly blown head gasket or junk rovers with cracked blocks. the radiator is so easy to replace don’t even waste your time
if you’re really desperate use the gm tablets those used to come stock in some of the caddys corvettes and old v12 xjs. pretty harmless stuff
Thanks for help . New radiator price I guess 1000$ not Worth it at all it's just denso radiator. I will get used one because it's in bad shape however before that I will use some epoxy maybe with some luck stop the leak
I do not know, in which country you are and I do not know exactly what your radiator looks like. I just had a brief look in ebay and I spotted some new radiators, which are supposed to fit for some Jaguar XJ's, and they are about AU$270. Thus, wherever you are: Check google and ebay first for a new radiator. I bought recently one very cheap (new) on ebay for a Ford Fairlane NL.
Don B (01-12-2023)
Better to fix it tight rather than risking an even more expensive repair.
I did use the Bahrs product on my beater Chevy Malibu with a bad head gasket, which is a $3,000 repair (about what the whole car is worth). A year later and, knock on wood, it is still holding. It even checks out on a block test. Had it just been a radiator leak I would have chosen to replace the radiator.
I tried now to find a X308 radiator for my 1998/99 Jag, I see now what you mean. It is the 1000 Dollar range, at least AU$1000.
But I also found this - I did not read all, but maybe they have inspiration for you:
https://www.jaguarforums.com/forum/x...-192255/page2/
Depending on where your leak is, maybe it can be fixed with aluminium welding.
Also: When you remove the old radiator, make sure to unscrew those 2 bolts, which connect the A/C radiator to the real radiator. You get access to those 2 bolts after removing the 4 bolds from the front, which hold the decorative grill. And then it is a bit of juggling required to get the radiator out and keep the A/C radiator in. This is to keep the refrigerant in the A/C system - release of that would be very harmful to the environment and render your A/C useless.
And another idea: At least here in our small town we have a specialized radiator shop. If you find one of those, and bring them your radiator, maybe they can fix it...
I would highly recommend everybody reading this to download the:
Car-Part.com app and just search for an X308 (you’ll get more hits with just an XJ8) radiator. An XJ8 & XJR radiator are the exact same. Yes I know they’re used parts but, it’s a direct bolt in. It’s up to you to call them and ask for the condition of the radiator. First things first, call them and ask if they ship parts if they aren’t local to you.
There is one more option if you really don't want to pull it out. If you can identify the location of the leak, and it's accessible, you might be able to jb weld it. Now don't y'all crucify me yet.
Drain the cooling system and dry out the area. Scuff the surface to allow for better adhesion. Use a high temperature jb weld epoxy, there might actually be a specific product for radiators. The repair is a bit hit and miss. I've heard of some lasting forever and some leaking again 2 weeks later. But . . . it'll probably cost you less than 20 dollars and 1 hour.
Don B (01-12-2023)
