Radio code - help please
Received 6,337 Likes
I can't remember the differenent freqs but some are AM and some are FM (only odd or even) and most people only listen to FM. I would check to make sure the radio is set to US or North America. I have disconnected my battery several times (1999MY XJ8) and I have not had to enter my radio code. I do have to enter the code on my 1992 XJ6 but I have that memorized.
I'll check my radio soon and make sure the system is correct.
Here is a TSB for info.
Be aware that when you change the market code, you will lose ALL presets!!
(users country and Radio Data System)
bob gauff
bob gauff
pretty sure my car is a USA car and I had tire blowout in THE HILLS HAVE EYES returning from vegas to PHX. Well AAA could not even find me for 3 hours and my battery went dead for at least an hour. I ended up needing the code and just had to call the service department with the last six digits of my VIN and got the code.
You need to set the radio head unit to US.
I just had a 2000 VDP in my shop last week and I disconnected the battery to replace the gearbox 'A'drum. I reconnected the battery and the radio displayed CODE. I found the code and reset the head unit from EUROPE RBDS to US RBDS and now the radio does NOT need the code if the battery is disconnected!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!
If you are in the US please set your radio head unit to US!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
bob gauff
bob gauff
My battery went dead last weekend. I removed it and put in on a charger for about four days. Just put the battery back in today and everything worked including the radio (no code required). Maybe a brand new battery is a different situation. Anyway, just give a Jag dealer a call and they should be able to fix you up.
It's true. Good call, sir.
I just got a second hand 2000 alpine HU for my 2000 XJR from a US parts folks so presumably don't need a code for it BUT I forgot that USA cars do not need code and so found these guys who will give you a code for $20:
JAGUAR CAR RADIO CODE UNLOCK DECODE BY SERIAL NUMBER | eBay
good luck
rand h
90 XJS 5.3 conv 5-speed
00 XJR anthracite
good luck
rand h
00 XJR anthracite
