Radio Removal XJ 1998
The process is fairly easy -- you need to remove the part that surrounds the shifter, then pry off (carefully) the wooden "ski slop" that surrounds the j-gate and the radio, etc. Be very careful not to break the wooden piece. Then you'll see how to unscrew the radio.
For more detailed info, you can search this site for removing j-gate or the like.
Good luck.
Good luck.
