Random Misfire
Old 03-10-2013, 01:20 PM
MomsJag's Avatar
Default Random Misfire
Passenger side cylinders not working. I've had mechanics check and no one has any idea what is causing this. Any help would be appreciated.
Old 03-11-2013, 09:42 AM
SuperSport's Avatar
Any Trouble Codes present? Did the engine get cleaned or wet recently?
Old 03-11-2013, 11:10 AM
JimmyL's Avatar
What year, model ? If a whole cylinder bank is misfiring - guess what - cam chain jumped and tensioners are shot.
Old 03-11-2013, 12:43 PM
test point's Avatar
Received 1,111 Likes on 932 Posts
Not much other than cam timing common to one bank. Time to pull the cam covers.
Welcome to the forum. Sorry about the situation that brought you here. Please put your year and model in your signature line. Helps everyone.
Old 03-13-2013, 03:49 PM
MomsJag's Avatar
Default More information
It's a 2000 xj8, and only codes are "random misfire"
Old 03-13-2013, 03:56 PM
dsnyder586's Avatar
You need to pull the cam covers anyway to check and make sure the tensioners are metal...so let us know what you find.
Old 03-14-2013, 04:20 PM
RidenXj8's Avatar
Yes please let us no I have same problem and same car and year
aode06
07-28-2023 02:26 PM
kingdom worker
11-14-2020 03:47 PM
pnwrs2000
11-17-2015 04:04 AM
reb1999
09-26-2015 08:41 AM
Quick Reply: Random Misfire
