rapid beeping after no start (not cranking) condition
I am new to the forum and also new to Jaguars. I recently bought a 1999 XJR that has been starting and running fine, but all of a sudden it won't turn over and then it beeps rapidly when I turn the key back to the off position, like some sort of security or safety feature. It did start once after I wiggled the shift lever. Is there an adjustment for the neutral safety switch or something? The ignition switch also locks out of the "start" position after the first attempt. The battery is new and the connections are secure. Thanks, Margo
Thanks! I found that if I moved the shift lever to the left (without the key in) it would beep. If it kept beeping after moving it back to the right it would not start; if it stopped beeping when pushed back to the right, it would start just fine. I have not had a chance to remove the console yet, but maybe I can get by for a time using this method.
MC36
US Lower Atlantic
09-01-2015 07:34 PM
