Rapid Flashing Light
On Gear Consul.......
Searched the forum for a fix and also rang the dealer.
Light flashed when turned ignition off.
No Electrics and couldn't restart car, locked car door manually and opened boot to check battery connections, tried key fob again, Electrics returned and car started ?
Read on the Forum it could be Immobilizer or Key Fob or low Battery.
Dealer suggests, Low Battery and to Trickle Charge.
I'm inclined to Replace the Battery and see if that's the fix.......?
Only had the car a couple of weeks.
rsa760041
23
09-25-2015 01:33 PM
