Ready to attempt the timing tensioner repair...just a few questions.
Good afternoon everyone,
I recently acquired a 2000 Lincoln LS with the 3.9L V8. I went out to look at the car knowing it had the common timing tensioner issue. It seemed like a mild case, barely made any noise. But of course, as soon as I signed the title, it started getting noisy consistently.
I've done a ton of research on the issue, and I see most people pull the valve covers and replace the tensioners and that's it. But I have some questions I wasn't able to dig up any info on:
1. My car is making a lot of noise, so I'm wondering: should I replace the secondary timing belt while I'm in there? I see tons of write-ups on how to do the tensioner, but not much information on how to replace the chain as well.
2. I see a lot of rebuild kits online for the primary tensioners and chains too. If my car is noisy, is it likely that these parts will need replacement as well?
3. I'm worried about internal damage of course, but if the car still runs and drives fine, it should be free of any bent valves/jumped timing/broken timing chain issues, correct? And no, I am not driving the car any longer, it is parked now.
I know these are tough questions to answer, but I won't be able to tear into the car until this weekend and want to make sure I'm prepared when I pull the VCs off.
Secondary tensioners that are failing generally make noise on startup. Continuous noise could be more serious. What you need to understand is that secondary failure is catastrophic and probably means replace engine.
So stop driving it, get the covers off and inspect. If the primaries are bad they are not likely to destroy the engine, and you can check them out also, although they are not as easy to see.
RJ_____________
95 XJ6 120K mi
97 XK8 86K mi
RJ_____________
95 XJ6 120K mi
97 XK8 86K mi
I parked the car, I'm just wondering if it would be wise to replace the secondary chains while I am in there or if they will even need replacement. Most write-ups I see they only replace the secondary tensioners, no belts or anything.
Got a link to the PDF? I searched and searched but could only find broken links.
It's right there in the "How to" section. Titled "Timing chain DIY" and the author is Blackonyx. When I click on the link, it openes MANY pages of PDF, but I don't know how to paste the link into my post. I read all those pages, but I will do uppers only with the zip tie method. Anyway,....I like to read all of it, just to have an idea what is involved.
Edited to add: It just dawned on me! I think you can't open it because you don't have enough posts. Maybe the moderator will have mercy on you, and upgrade your membership, so you can open it. The links are not dead.
But I'm wondering, for those who have done the repair, why did or didn't you replace the secondary timing chain? And how can you tell if the primary chains/tensioners need replacement?
Well, it kind of boils down to your risk tolerance.
An extra $150 for new chains is cheap insurance if you are going to keep the car 100k more. If you are going to do uppers and lowers there is no extra work involved so it boils down to $$.
IF you are just doing uppers with the zip tie method, chains add more work.
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
