Realistic market value for my xj8?
Hi all,
I am testing the waters a little bit regarding my 98 XJ8 Vanden Plas.
I bought this car a few months ago with only 3400 miles on it. It was owned by an older couple who drove it once a week to go get the mail in their small town.
The car now has 7200 miles on it. It runs and drives perfect with absolutely no problems. Everything works properly and the car still smells new. The interior is like new and the car is immaculate.
The paint is flawless except a small scratch on the rear right door. Original P4000 tires.
I also have original "monroni", sales literature, owners manuals and service records.
It has had the throttle body replaced as well as fuel pump and filter. It has the H/K stereo upgrade with changer and it does not have the heated seats.
So...the question. What should I ask for it?
It is topaz with light interior, two sets of lambswool mats.
Any thoughts?
Any thoughts?
Thanks Doug. I do intend to replace the tensioners and water pump. With the miles what they are, I have gotten mixed opinions on the time frame. When I called Jaguar service, they laughed and told me that they don't even consider the car broken in yet.
Having said that, and assuming it had new tensioners, new water pump and tires...what would be a good place to start with price?
After tensioners, water pump and tires are replaced, I'm thinking about $12,000. Just My opinion. There is not much to compare with on this age of a Jag with those miles. It does have the nicasil coated cylinders but that might not be a big problem these days as long as the engine is never overheated. They can be a bear to start when shut off while cold.
Doug
Doug
Sinister...I'm in Oregon near Portland.
Doug...I really thought through the nikasil issue as that was my biggest concern with this era of Jag. After reading most of the compiled research, I figured since the car only had about 1,000 miles worth of the "bad gas" of the late nineties I figured that I was pretty safe considering the linings. Naturally, I was watching closely for hard starts, blow-by and oil in intake.
The car never overheated according to the previous owner.
I'm wondering if you meant to draw a correlation between it overheating and the nicasil? I'm curious how they are related. Does the nicasil respond differently to getting hot?
I just changed the oil today to full synthetic and flushed the coolant. I am going to do the brake fluid next week and new tires tomorrow.
12,000 is what I thought could be the high end.
Thanks for the thoughts.
Now that the sulfur fuels are gone, overheating is the last major threat to nikasil.
TTYL
David
Last edited by DavidB; 01-28-2010 at 01:09 AM. Reason: Quoted previous message to clarify
Book on that car is around $6000. The adder for the low miles is $3100. So book is around $9000.00.
It's going to be a narrow market above that price since it's going to be tough for someone to finance this vehicle unless they have a relationship with their bank.
If it's the right colors it could bring $12K. Like they say in the dealer sales meetings, "There's a butt for every seat".
It's a real book called the Black Book. I quoted the retail price. Remember, it's just a book. Same goes for KBB NADA and others. They are reference only not gospel.
Either way, price it at the $12K and see what happens. You never know what the market will bear until you put it out there.
