Rear brake lights
Guest
Posts: n/a
Hey guys,
I had my fuel pump go out on me and replaced it myself, since then my rear brake lights do not light up but will work if I step on the brakes. Is it possible that I disconnected something and possibly forgot to reconnect it? Or could it be the fuse? and if so where would I find it? Any help would be very much appreciated. Its a 99 xj8. Thanks in advanced.
OK, we had our chuckle. Well, you had to take the wiring harness loose for the lights to get the D$#MNed fuel tank out, so YES, I would start with those connectors and make sure you didn't pull a wire from one of them. Then check that you did not skin a wire (near the right hinge?) and if so, fix it and change the fuse. Look up which one in your owner's manual.
99xk8guy
06-05-2023 06:28 AM
innzane
09-02-2015 10:08 AM
