rear end banging
If it's clunking coming from the rear end, and not the transmission, it could be something less catastrophic like the driveshaft jurid couplers, half shaft U-joints, rear subframe bushings, etc. and that depends a lot on how exactly the clunking behaves.
Slow gear changes and banging into gear does sound like A drum though.
When my A drum went out I originally thought I got rear ended. When I looked in the rear view mirror and didn't see a car I knew something was wrong. The only warning I had was a couple odd shifts then the BANG. So to me the trans bang sounded like it came from the rear. Any codes? lights?
03-13-2007 12:07 PM
