Rear end sliding at 60mph
Hello guys my car unfortunately is sliding badly I changed the shocks with green billsten and new dount bushing slight improvement but still sliding at high speed I could feel the air moving the rear end of the car It was dangerous moment .
also I noticed the shocks are very soft ! The old one were stiffer I heard the green is stiffer but this one very soft if I push the car trunk down and it bounces easily
could it be the shocks? But I bought it new now what cause this ? Rear wheel bearing? Rear bushings?
Alignment is okay . Also if I reduced the tire pressure does it help?
I will take it to shop next week but I need to have idea what can cause this . 150k miles xj8 2001
I honestly can't believe both shocks are defective but the bouncing is abnormal
No cracks in springs
40psi seems high, at least relative to factory recommendations (34psi). Don't know if others run that high a pressure, and it probably doesn't have much to do with your weird feeling of bouncing.
"No play" eliminates about half the list. I'd personally inspect the subframe bushings (the two big ones towards the front of the rear subframe, that mount in the A-frame). Maybe try prying on them sideways with a prybar and see if the frame moves. Or you can just unbolt one of the supports to visually inspect it, if it's that trashed that it feels like your car is being blown around you'll probably be able to see it from below.
Truss bushings will be able to be easily visually/prybar inspected while under the car as well.
RA110623 (02-07-2023)
40psi is high, but probably won't cause your issues. Definitely check everything under there with a pry bar and make sure the springs are not broken. Haven't seen or heard of that on an XJ, but I've had more than one Mustang with a broken coil spring.
The bounce is certainly odd. Are the top bushings on the shocks, everything installed properly? As @nilanium said, get under there and check everything. With such an issue you're bound to find the problem rather easily.
Oh the transmission also is saying goodbye 👋 it's a jaaaaaag . Funny I just changed the tensioners
Thanks for the help
