Rear heater vents 98 xj
Looked for info on search found nothing.
I get no air ,Hot or Cold through center rear seat heat vents.
Not sure how its controlled?
Did turn the open close knob still nothing.
Haven't taken center console apart yet to see.
Maybe something under dash.
Thanks for the help.
Paul
Paul
Fyrplg (06-13-2012)
I thought the same when I first got my car, but it is as Stu says - it is a very reduced flow to the rear vents.. when I first got the car I read the manuals and expected the back seat area airflow to be as active as the front but it is more of a gentle waft in truth.. but it does still help the kids in the back nonetheless :-)
The air flow through the rear vents is weak--that is normal.
Assuming the damper is open there should be *some* air coming out, but don't expect anything like the volume of air experienced from the front vents.
You'll only get airflow when the climate control is set to the panel vents. If you really want to test the operation, select panel, set fan speed to maximum, and close the dash vents. Then you might have sufficient flow from the rear vents to confirm they're working.
Fyrplg (06-25-2012)
