Rear hub bearing replacement write-up
Received 1,794 Likes
Your talking about two metal products rubbing against each other for quite a time. I'd suggest you go to a junkyard and do some comparing with a micrometer and sourcing possible replacement parts while there. I'd also watch the video KC provided in post #15 just to get an idea of the parts in that area that will also wear and may be gone. Check https://www.car-part.com/ for the parts and/or full on assemblies as well...there are other sources for yards.
Please provide go into your User CP and add your location, model and year so we can direct you more efficiently. NA and EU models each have certain nuances, so this is helpful to you...cheers.
Yeah, mine are the ccc3598.
they aren't available anywhere.
I was hoping that it was an insignificant change and that the 2 part numbers were interchangeable as the other type, "CAC9483P" are available
They look the same to me, and are advertised as fitting an XJ40
but I know it doesn't work quite like that.
Well, I have to say, this is the wrong forum for your issue, I should had paid more attention to 1994. The XJ40 is... https://www.jaguarforums.com/forum/xj40-xj81-25/ ...those folks will have more direct info and resources for you. Also, don't forget to check in the Marketplace, top task bar, 5th option from the left for member items for sale... https://www.jaguarforums.com/forum/p...classifieds-9/
Always check the Sticky's at the top of each forum for possible solutions other members have posted specific to your issue.
This should help you a bit more as well... https://parts.jaguarlandroverclassic.../brand/jaguar/
...and... https://parts.jaguarlandroverclassic.../brand/jaguar/
