Rear hub question?
Old 02-03-2017, 01:01 PM
Amphicar770's Avatar
Default Rear hub question?
I have the rear hub off of my 2001 XJR, just had wheel bearings replaced.
I am looking at posts about the "pivot bearings" but in all those pics it looks like you remove a washer / shim and the bearings are right there. When I look at mine it looks more like a rubber control arm bushing, kind of like on an older Porsche. The kind that you generally press or burn out.
Did the design change or am I just missing something obvious?
Old 02-03-2017, 02:43 PM
nilanium's Avatar
I think that's just the dust seal to the bearing. Googling the part no I read off from your picture (lm11900ea) comes up with tapered roller bearings as a result.
Don B (02-03-2017)
Old 02-03-2017, 03:06 PM
Received 13,205 Likes on 6,553 Posts
Yes, that's the grease seal that is part of the bearing assembly:
Here's a photo from SNG Barratt showing that the seal comes with the new bearing (shown with the cup or race covering the cone - in the photo above the race is still inside the hub carrier):
To remove the bearing, it's easiest to tap the pivot pin sleeve through from one end, and the bearing on the opposite end will come with it, so be ready to catch it in case it pops out. Once you get one bearing out, use the pivot pin sleeve to tap out the other bearing from the other side. The pivot pin sleeve is part 13 in this diagram from jaguarclassicparts.com:
BTW, the same bearing part numbers were used on all the XJ40s, X300s, X308s and X100s.
Cheers,
Don
XJRay (02-07-2017)
Old 02-03-2017, 10:23 PM
Thanks. Did not want to press it out without confirmation.
One more semi-related note. I removed the axle shaft and had new u-joints installed. The nuts holding axle shaft on the differential side have seen better days. Anyone know what size / type threads those are. I took to hardware store. Seems about 12mm but they did not seem to spin into anything. Could be that threads are deformed (they were smoking when impact wrench zipped them off).
Old 02-04-2017, 12:13 AM
nilanium's Avatar
I think they're SAE threads, the nuts themselves are 11/16. motorcarman might know, the sizing is coming from him as well.
Old 02-04-2017, 09:05 AM
Yes, they are SAE threads and the nuts are 11/16 in. Standard new axle nuts fit but they have a wrench size of 3/4 in. so there's even less clearance to get them on and off, but doable.
XJRay (02-07-2017)
Old 02-04-2017, 11:56 AM
Thanks. Never even considered that they are not metric.
Anyone have the part number for the nuts. I see the bolts on diagrams / sites but not the nuts. Thanks.
Old 02-04-2017, 02:50 PM
nilanium's Avatar
I think it's NV607041 it's listed as an "unillustrated part - nut" on the halfshaft page, google images looks about right
Old 02-04-2017, 04:03 PM
plums's Avatar
Received 2,184 Likes on 1,624 Posts
Maybe not. The linked page calls out the compatible models and the X308 is not one of them.
Old 02-04-2017, 05:17 PM
nilanium's Avatar
I got to the part through the x308 half shaft parts section. Motorcarman also said it is the same nut that's been used for a few decades
Old 02-04-2017, 07:44 PM
Seems like either
NV112051J. Or NV607041
Old 02-04-2017, 09:27 PM
I just checked my records and the stud threads are 7/16 inch. I didn't record the pitch but it's a standard SAE thread.
On the left is an original nut that takes an 11/16 inch socket, and on the right is one of the new axle nuts I found at a local hardware store or Tractor Supply Co. for about $0.25 each several years ago. The only downside was that they take a 3/4 inch socket, and access is already limited by the mounting flange and U-joint yokes.
According to jaguarclassicparts.com it does appear the correct Jaguar part number is NV607041. Jaguar Merriam lists them for $1.26 each, though shipping may easily double the cost of a set:
www.jaguarmerriamparts.com/parts/2001/Jaguar/XJR/index.cfm?siteid=215718
SNG Barratt has options at $1.17 and $0.54:
SNG Barratt - The Ultimate Jaguar Parts Specialist
Just to confirm and expand upon what Bob mentioned earlier, the SNG Barratt listing states this same nut was used on the XK140, XK150, E-Type, Mk II, Mk IX, Mk VII, Mk X, S-Type (original), 420, XJ6 Series I-III, XJS, XJ40, X300, X308, X100, and several early Daimlers.
Cheers,
Don
The following 2 users liked this post by Don B:
SNG Barratt USA (02-09-2017), XJRay (02-07-2017)
Old 02-04-2017, 11:10 PM
plums's Avatar
The basis of my "maybe not" was the following statement on the
linked page:
PART NO. NV607041 - (UNILLUSTRATED PARTS) PARTS
Part suitable for use in:
•XK8 Coupe/Convertible from (V) A30645
•Daimler Limousine
•XJ6 (2.9, 3.2, 3.6, 4.0) from (V)500001 to (V)667828
•XJ6 & XJ12 from (V)667829 to (V)708757
•XJ6 & XJ12 from (V)667829 to (V)708757 - Canada/USA
Likely an error on the page if it was indeed found by following
all the clicks after first selecting the correct vehicle.
Knowing this I said "maybe not" rather than just "not the right number".
Old 02-08-2017, 12:11 PM
OK, this seems like a dumb question.
I am trying to reinstall axle shaft. Both rear wherks are off the ground, tranny in neutral.
I can spin the other side with wheel easily. The axle side seems to get stuck about half way either direction. Using a pry bar but don't want to break anything. Can't install retaining nuts without being g able to turn it. Help!
Old 02-08-2017, 12:24 PM
Can you turn the driveshaft/propshaft to see if that frees up the axle movement?
XJRay (02-17-2017)
Old 02-08-2017, 04:53 PM
Looks like something in the partially installed axle was binding up. Once I got one of the other nuts tightened all was good.
Everything is back together. All said, it was not too bad a job although I did have to let machine shop press hub from carrier. Worst part was the parking brake springs (I hate brake springs).
I had u-joints replaced just because axle was right there. Even painted the caliper red, it makes car go faster. Haha. Bearings, etc greased with redline synthetic.
I wonder if it is now an inevitabilty that other side will soon go as well?
Thanks for all the help given here.
Don B (02-08-2017)
Old 02-08-2017, 05:34 PM
nilanium's Avatar
Did it fix the noise? Also, did you ever find play in the output bearings once all the good parts were back together?
Old 02-08-2017, 06:29 PM
Noise is gone. No play in the wheel at all. In my other post I show picture of failed bearing. Machine shop said it was pretty bad. Fortunately no apparent damage to hub or carrier.
