Rear lighting issue.
Been getting the check rear lights message, I checked all bulbs,connections & cleaned contacts. I notice that my driver's side running light does not illuminate unless I have the fog lights on. Brake lights & everything else is fine.
Is this the reported security module issue I've seen here.
It is if it comes on when you tap the brakes. Quite a few threads. If you go on eBay to find a used Security Locking and Control Module, try to match numbers with the one you have. There is also a company (Idaho, I remember faintly) that will rebuild and guarantee yours for about $200 round trip.
What doesn't work, in the long run, is the bridging technique in one of Robert DIY's YouTube.
King Charles (02-22-2016)
I found a used one on eBay; the series has to match, particularly the freq for your fobs to work. My plan was to send the old one off for repair, but the new one worked.
There is a wire that runs to the upper light that is not controlled through the SLCM; you could bridge both rears off that line while the part is being repaired. No fobs, tho.
Do a search, Ross told me and RobertDIY how to do it.
WTB[SouthWest]: 1992 XJS Driver's Side (LHD) Headlight & Bezel
msteiner805
02-14-2016 10:14 PM
