Rear nearside passenger door will not open from the inside!
Received 1,794 Likes
Does the lock actuator work?...and does the handle feel like its giving easily or is it binding. Because you specify the inside, I can assume the exterior handle works?....I suspect a stretch cable.
You can remove the bezel and then the handle assembly and you may see some stress releases on the cable there. If not, you will need to do this anyway, ...remove the door card and inspect the cable.
A.J.P (04-28-2020)
jagnew
07-22-2017 07:45 AM
