Rear park sensors
I checked my old XJ8 Vehicle Care Manual and there's no dedicated fuse or relay listed for the Reversing Aid.
The Parts Manual is light on detail but does show the main components:
The system is controlled through the Reversing Aid Module (item1) in the luggage compartment which is likely to be bolted to the rear or side panel somewhere around the spare wheel. You can tell what you're looking for from the drawing. Locate this module and you should then be able to see the feed harness. Highly likely this has an in-line fuse.
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
innzane
09-02-2015 10:08 AM
