Rear pivot bearing shimms
Yes, #16 MHC3397AA1,2,3 etc. It comes in thicknesses from 3.905 to 5.505 mm in increments of 0.05 mm. When replacing the bearings and/or the sleeve, you need to set the preload to the factory spec by inserting the required thickness of the shims. Putting back the original ones may not provide correct preload or you may even have some backlash.
