Rear shocks
That's what my local guy wants for the rears: he says they have never changed rears in less than 3 hours per side (rate guide shows 3.5 total) at $95 per hr. I think a alignment shop up the street might be able to do it quicker. Dealer is out, way too expensive and can't guarantee the work since I am bringing the shocks (quoted $300 per shock).0
Did the fronts myself, pretty easy, much easier than JTIS suggested, but I had already repaired the upper bushings so I was familiar.
Rear Damper, vehicle set warranty time is about 2.5 hours.
A real world estimate would be around 4 hours total.
If I was greedy I guess I would need to move to these big cities and charge exorbitant prices, but I refuse to live in a city so I will just charge reasonable fees.
After replacing a few dozen rear dampers, they become fairly easy. They are not difficult and do NOT require a spring compressor if the lower plate is pried downward enough to drop the lower control arms.
People make this more difficult than it needs to be.
bob gauff
bob gauff
The following 3 users liked this post by motorcarman:
When I was under my car after reading the rear shock replacement procedure in JTIS, I wondered if this was possible. Good to know I wasn't pipe dreaming!
I have described the way to lower the control arms enough to let the springs fall out.
I am sure I have written the procedure several times in the past.
A mechanic in the Jag dealer I worked at used to find shortcuts to everything.
We all used the JTIS method but he thought it was a waste of time so he removed the 4 bolts from the diff and rear subframe bracket and used a 4 foot prybar and bent the rear of the plate down until he could jam a socket or piece of wood to hold it.
The arms will fall low enough to remove the springs and dampers.
Put a trans jack under the plate and lift it back in place to install the bolts.
You can use a floor jack if you are not using a lift and the car is low enough.
bob gauff
bob gauff
Platinum XJR (10-03-2013)
Looking to replace my rear shocks - 2000 XJ8 - Rock Auto seems to have good prices on the KYB shocks. They also list spring seats and spring isolators - does anyone have an exploded view of the shock assembly? I know the isolator / bushing at the top of the spring mount, where it joins the body, is toast - not sure what the listing means by spring seat - I do not see anything between the spring and top plate. Thanks
This will help :
Damper and Spring Fittings-Rear - Parts For XJ Series from (V)812317 to (V)F59525 (X308) | Jaguar Classic Parts UK
The spring seat you mention is probably the rubber "pigtail" seat that sits under the bottom end of the spring (item #4 in diagram). It will in all probability be on its last legs as well ....
AndyP
Guy-Pierre Boucher
09-16-2015 05:55 PM
KarimPA
09-12-2015 08:15 AM
Tar
09-06-2015 11:24 AM
