Rear Sub Frame on 2003 XJ8
Old 07-05-2015 | 10:51 AM
BorisV's Avatar
Default Rear Sub Frame on 2003 XJ8
Bear with me, I'm a female so please be patient! I have a pristine, one owner 2003 XJ8. It has 32,000 miles on it and I love this car. It's my 3rd Jag but as this was the last year they made this model, I want to keep it. My car went to dealership for 30,000 service and they are saying that the Rear Sub Frame is rusted (I live in Ohio, lots of salt) and it will be $4000 to replace. Part will be new, shipping from the UK, they say part is $1500 and the rest will be labor. Thoughts?
Old 07-05-2015 | 02:05 PM
Panelhead's Avatar
Default Find an independent garage
Get a solid used sub frame from a junkyard down south. Couple hundred and then another 3-4 hundred labor.
Look at the thread by Naso. He documents changing the front subframe on his.
Don B (07-05-2015)
Old 07-05-2015 | 04:30 PM
Don B's Avatar
Hi BorisV,
Welcome to the Jaguar Forums!
I have moved your thread from the forum for the X350 to the forum for the X308, which is the Jaguar factory project code for the XJ8s made from 1997 to 2003. If your U.S.-spec car really is an X350, let me know and I'll move your thread back.
If the problem is just surface rust, it may be possible to simply clean it, treat it, and repaint it. If it is bad enough to pose a safety risk, then Panelhead's suggestion of a good salvaged part is your best bet. I would recommend that you get a second opinion from a good independent shop that specializes in Jaguars or European vehicles.
If only the lower A-frame (Part 12 in the diagram below) is affected, it can be replaced in a few hours without dropping the differential and the rest of the independent rear suspension (IRS):
If other components need to be replaced, the entire IRS can be dropped in a few hours and reinstalled in a few hours more. The photos below show how it's done on our '93 XJ40, which is actually quite similar to a X308:
Welcome to Jag-lovers - Members Photo Viewing Page
Since we're a friendly group, please visit the New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum and post an introduction so we can learn something about you and your Jag and give you a proper welcome.
Finally, there is no reason to apologize for being female. We assume that since you're smart enough to join Jaguar Forums, you're smart enough to learn anything the rest of us can, and we're all here to learn from each other.
Cheers,
Don
XJRay (07-06-2015)
Old 07-05-2015 | 08:30 PM
Jhartz's Avatar
Find a good independent who is not stealing from you. Rust. Of course there is rust. It ain't cancer.
Old 07-05-2015 | 10:39 PM
plums's Avatar
+1 to the post above.
Highly unlikely even in Ohio. Although, oil spraying is really
helpful. Even then, I have seen the same part from 1995 models
with 200,000 miles in salt country that would be considered safe
although a little ugly to look at. I even paid money for it. Nothing
a coat of paint won't fix.
Now, if it is actually justified, part #12 is the likely culprit.
From playing with one of these, I suspect that a creative person
could replace it without dropping the remainder.
In either case, if work is done, make sure parts #13 on each side
are replaced at the same time or at least carefully inspected.
Labour at $2500 and $125/hour shop rate would imply 20 hours.
That's way over the top or at least very generous.
The following 2 users liked this post by plums:
Don B (07-05-2015), xjay8 (07-06-2015)
Old 07-06-2015 | 12:59 AM
Mark SF's Avatar
Generally, your best bet for a Jag of that age is to find a good independent shop that specializes in Jags or British cars in general.
I don't subscribe to the line that dealers rip you off, but they are the most expensive option. At most dealers the service dept is the most profitable part of the operation.
Old 07-06-2015 | 03:07 AM
plums's Avatar
Thumbs up
Missed the fact that the advice had already been given.
Old 07-06-2015 | 08:02 AM
xjay8's Avatar
Ditto like Plums sez ;o))
Frankly, I think your friendly ******* is busy drumming up trade!
Get it independently inspected and I feel sure it's nowhere near as bad as they make out.
Old 07-06-2015 | 08:44 AM
rocklandjag's Avatar
I agree with everyone else, take the care to an independent shop for another opinion. It is very unlikely that you need to replace the subframe
99xk8guy
06-05-2023 06:28 AM
Shawn Svacha
11-04-2019 02:47 PM
dsnyder586
04-04-2019 02:38 PM
EZDriver
09-08-2015 09:25 AM
OkieTim
09-02-2015 12:48 PM
Quick Reply: Rear Sub Frame on 2003 XJ8
