Rear suspension alignment
2000 XJR; Recently had a four wheel alignment done and was told the rear suspension was out of alignment. I was told that there was no way to align the rear as no adjustments are available for the independent rear suspension components.
I have previously had such alignments done and no such issues had ever appeared.
Does a rear subframe exist on this car to which some adjustments could be made or cause the rear to be misaligned?
Rear toe is dead-easy to adjust using the eccentric bolt. Rear camber adjustments are more involved. I too was told (wrongly) that no rear adjustments were possible when I paid for an alignment after replacing my steering rack. Rear toe on my rear passenger wheel was off enough that the car drifted slightly on the highway after the front alignment. I ended up adjusting it myself and it tracks straight as an arrow now.
Received 2,193 Likes
Digital Will
03-06-2020 03:50 PM
FS[SouthWest]: XJ40 used Rear Spring set for NON-SLS
motorcarman
10-12-2016 11:36 AM
