Rear Turn Signal Problem
My 2003 XJ8 rear left turn signal started giving the faster click sound so I thought my directional bulb was blown. I changed out the bulb and it's still not working and the car thinks the bulb is blown. I've tried switching the panels to see if it was a bad connection at the bulb. Same issue. I also tried splicing a wire to a ground to see if it could be a bad ground. I used the black wire from the harness - this did not work either. Can't seem to find a solution. Any thoughts? I'm sure I can fix this myself if I knew where to look. Thanks in advance for any help. - ANTXJ
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
AntXJ (11-08-2011)
AntXJ (11-08-2011)
Thanks for the heads-up. I did switch the bulb from the "working" right rear panel and it still didn't work. I purchased the bulbs at Auto zone and we looked up the right part for my model and year. I've had some other electrical issues with this car. I had to replace every door latch to get my dome and puddle lights back. Also, I had an interior trunk light problem which I solved by rewiring. I suspect this could be a wire issue as well. Oh well, if I didn't love these cars so much, I would have given up years ago. Thanks again!
Cheers,
AntXJ (11-08-2011)
One is in the boot, above the gas tank about 8 inches to the left of the RH boot lid hinge. It has a bail of sorts that lifts to release the connector. You could check it and see if anything turns up. There is another one just like it at the right side of the fascia just below the A/C vent. You will need to remove the glove box to access it. Worth a try.
Good luck!
AntXJ (11-08-2011)
holybananas (04-03-2012)
BrentGardner
28
04-26-2024 03:08 AM
Tony K
03-26-2024 01:53 PM
