Rear wheel lockup
Rear wheel lockup
The other day after driving for most of the day, just as I rounded the turn onto my street the back wheels locked up. Luckily I was only going like 15 so it wasn't a disaster. The driveshaft had been making an intermittent noise leading up to this, so I assumed it had broken. Looked under the car and saw nothing out of the ordinary. I then backed the car out of the road, and pulled onto the shoulder.
I had the car towed home the next morning and the driver said it rolled onto the rollback and rolled back off with no problems. I have since moved it around my property a little, and have had no wheel lockup or other signs of trouble.
Anyone have any ideas? I got under the car to visually inspect and there is nothing out of order.
If it's one wheel, and it made a squealing noise leading up to it, it's likely a bearing somewhere between the diff and the wheel (e.g. wheel bearing). If both wheels locked up it might be the diff, drivetrain, gearbox...
Hard to fully diagnose over the internet, but your problem is definitely that at least one spinny thing decided to stop being a spinny thing
ShootJoeC (08-29-2023)
