Rear wheelarch repair panels
Could somebody confirm my thoughts as correct or not?
I have some corrosion on my rear L/H wheel arch. I will get it repaired but want to do it properly so I intend to cut out all of the old rust, and weld in a repair section. Only looking at about 4 cm but as with all rust it seems to go a bit further that it first looks...will do the welding and finishing myself, and get a bodyshop to paint for me.
Whilst I can look to fabricate a repair piece from steel sheet, I would rather get a repair panel and cut out the piece I need....But they seem hard to find.
Are the older X300 wheelarches identical to X308, as I think I have found one for an X300?
I've seen rear wheel arch repair panels for sale at: www.justjagsuk.com for £31.50 excluding VAT for the LH arch. It states that it can be used for the XJ40, X300 & X308 models so the rear wheel arches are the same on the X300 & X308.
richard thomas (12-01-2012)
SNG Barratt USA website
SNG Barratt Jaguar XJ40/X300 Parts Catalogue
XJ40 wheel arch repair panel
RH CAP516RP 1
LH CAP517RP 1
WHEEL ARCH REPAIR PANEL RH PRODUCT CODE: CAP516RP RETAIL PRICE: $42.28 ($42.28) inc TAX
SNG Barratt - The Ultimate Jaguar Parts Specialist
WHEEL ARCH REPAIR PANEL LH PRODUCT CODE: CAP517RP RETAIL PRICE: $42.28 ($42.28) inc TAX
Just Jags UK website links
Jaguar X300, X308, XJ40 Rear Wheel Arch Outer Panel - RH (CAP516RP-A) £31.50
Jaguar X300, X308, XJ40 Rear Wheel Arch Outer Panel - RH (CAP516RP-A) - JustJagsUK.com
Jaguar X300, X308, XJ40 Rear Wheel Arch Outer Panel - LH (CAP517RP-A) £31.50
Jaguar X300, X308, XJ40 Rear Wheel Arch Outer Panel - LH (CAP517RP-A) - JustJagsUK.com
Jim Lombardi
RH CAP516RP 1
LH CAP517RP 1
Jim Lombardi
The following 2 users liked this post by jimlombardi:
mgb4tim (08-17-2013),
runnerpaul (08-18-2013)
CAP516RP - Rear wheel arch outer panel - right hand side.
This rear wheel arch outer panel will fit the Jaguar XJ40, X300, and X308 models.
Note; on the X300 and the X308 models you will need to cut off around 6 inches (150mm) of the rear section of the panel in order it will fit where the rear bumper (fender) meets the wheel arch.
The arch will not need this modification for the XJ40 models.
also applies to the LH CAP517RP - Rear wheel arch outer panel - left hand side
Info provided by JustJagsUK.com
Jim Lombardi
Jim Lombardi
mgb4tim (08-19-2013),
KarimPA
09-12-2015 08:15 AM
