Rear window doesn't defrost
The following 3 users liked this post by avern1:
The relays are cheap to replace -- $12.
The internal relay contacts could be pitted depending on the frequency of use. The defroster is high amp. The contacts that you can see are rarely the problem -- the internals flex when you pull them out .. often realigning the internals. It may work for a while .. but will fail again.
scottyg
06-15-2022 12:11 AM
RDMinor
12-12-2015 10:27 PM
