Reduced bite in brakes, kinda spongy - are new pads needed?
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
The brakes are feeling kinda spongy, with less bite - is that a sign the pads need replacing?
The front pads are from the previous owner (6-years ago), so no idea how long they've been on the car.
The rear pads are 2-years-new (and ceramic) and the pads they replaced had Jaguar logos on them, so could very well have been the original set since you'd be crazy (or crazy-wealthy) to buy OEM pads for an x308. If indeed they were originals, they lasted a record-breaking 125k miles!
You need to pull the wheels and check: minimally, a brake bleed to replace the old fluid and to check the hoses. Water in old fluid, along with air in the lines will give you a spongy brake. So will a hose that expands (paid, once, for a new caliper and busted knuckles on my wife's POS Maxima, only to find it wasn't a bad caliper, but a soft hose).
Received 2,625 Likes
Refer to the vehicle Owner's Manual for recommended service intervals. Brake fluid generally should be replaced every two years, or if it becomes very dark from absorbing moisture.
Check to make sure the calipers are sliding properly as a sticking caliper can also create a 'spongy' pedal feel.
vdpnyc (05-10-2016)
But not meaning to offend: when I see questions like yours, suggests you need to take it to a shop.
vdpnyc (05-10-2016)
Peter Langan
26
04-06-2016 01:42 PM
