Remote central locking fault.
Hi all,
Can anybody tell me the difference between central control locking modules with part numbers LNC2600JD and LNC2600JF PLease?
I have a suspected faulty module in my 2000 XJR, currently fitted with the JF suffix part, I wonder if the unit with the JD suffix would be interchangeable, as I've found one for sale (with a new fob).
If so, would it need programming by Jaguar, or could I employ the light stalk flash/key turn story that's often discussed?
Any help would be much appreciated.
Thanks,
Tony.
Thanks,
Tony.
Alvin,
Much as I'd love to be able to explain a definitive answer on the programming of these key fobs to everybody, I was lucky. The fobs I bought were already paired to the control module, so it was simply a plug and play affair.
3 bolts, 3 electrical plugs. unit is under the boot (sorry, trunk - I see you're in Dallas!) compartment fuse box. It took about 5 minutes.
Regards,
Tony
Regards,
Tony
Alvin Burns (04-20-2012)
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
zdrapec
09-25-2015 05:49 AM
