remote code numbers
Hi all,
I need to order another remote for my 2001 XJR and I want to make sure I order the right one , so can someone let me know what are the numbers behind the remote I need in order to order the right remote? Dealer told my VIN was showing a remote code : LJE 2610-AB , but what about the other numbers on the back of the remote?
Thank you so much!
Thank you so much!
Received 3,907 Likes
Jean, what numbers are you seeing. Not having a remote in front of me of your style, I'm not sure what numbers you are seeing. I can tell you that one of the numbers that you are seeing will be labeled "FCC ID:" with some series of numbers and letters after it. All that happens to be is a code the US Government has for the particular device indicating that it conforms to a certain frequency range, transmits at a certain power, transmitting a defined set of information.
The big thing that you want to be looking for is the part number (LJE 2610-AB). You meet that, the rest of the numbers on the remote should be identical. Just make sure that the remote has the "AB" on the end. The AB as I recall is the model identifier and over the years, if a change is made to the security system, that gets updated as the data the remote is sending has changed.
kabs3012
09-12-2015 10:40 AM
