Remote control does not roll up the windows
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Jaguar xj v8 Souvering 4.0 año 2001
Hola.
No sé qué le puede pasar al mando porque cuando activo el cierre con él, se cierran todas las puertas pero no se suben las ventanillas, se quedan abajo. Es posible que el mando no lleve esa función. . Está reprogamado y sigue sin ejecutar la subida de las ventanillas
En cambio, si cierro el coche con la llave, las ventanillas sí su suben y se cierran todas.
A alguno os has pasado ésto.
Gracias por anticipado.
Un saludo,
Abanderado
Hola.
Un saludo,
Abanderado
This is how Google Translated this post...........................
Jaguar xj v8 Souvering 4.0 year 2001
Hi.
I don't know what can happen to the command because when I activate the lock with it, all the doors are closed but the windows are not rolled up, they stay down. The remote may not have that function. . It is reprogrammed and it still does not execute the raising of the windows
On the other hand, if I lock the car with the key, the windows do go up and they all close.
This has happened to some of you?
Hi.
Seems normal to me, I don't recall the remote being able to open or close the windows, only the key. Unless I missed one of Carnival Kid's "Did you know your X308?" updates.
anduha (09-27-2020)
anduha, yes, pretty sure the only ways to "automatically" simultaneously open or close the windows and/or sunroof is either with the key held in the driver's door to close all open windows/sunroof upon exiting, or open all windows with the key held in the driver's door upon entry. The other way is a safety feature whereby, with the key in the ignition, if you press and hold the door-locking button on the dash it will lock all doors and simultaneously close all open windows and/or sunroof. But the remote fob doesn't have the ability to operate the windows/sunroof.
Hola.
Un saludo,
Abanderado
Hola.
Un saludo,
Abanderado
We are an International forum and the single language used is ENGLISH. You may have seen there are no posts in any other language.
Harlethan
07-28-2020 03:44 PM
seventhjag
04-23-2015 08:14 PM
