Remote fob only works close to the car
Untill a few days my remote only works when held close to the rear windows.
Put a new battery in the fob but still the same.
I also programmed my spare fob in the car ,but both do the same ,they only Work when held Close to the rear window/s
Gave my car a hard reset ,hope it solves ,but no difference .
I believe the rear window is the antenna ,any ideas what could be the
Problem ,reciever where is it located ?, loose antenna ,or both fobs gave Up.?
Any help will be apprecitated.
Thank you for the input
Ok i pulled the plug from the rear window antenna and i noticed the fob works ever worse ,have to keep it just a bit closer to the rear window .
So the signal increases only a bit more with the antenna plug on
The heating/antenna elements in the rear window might have a internally Fracture ?
I wil clean the antenna plug between the battery and fuse box have to loosen the battery first to get to it .
If you have a carbon pencil you can run that over the contacts on the rubber buttons as well, as these can sometimes wear as well
I give up ...nothing helped months later ..both remotes stopped working
I Replaced the security module under the fuse box in the trunk
with the same part number ,its stil and before this with the old module
stuck in valet mode ..
I cannot get it out of F...stupid valet mode ,the remotes dont work anymore and
using black key in the door only opens and shut the doors and activate the
ignition NOT THE REAR TRUNK AND FUEL cap cover .
Both remotes dont work anymore and yes they have NEW batterys and i tried
one new fob nothing....
my trunk and my fuel cap cover doesn,t open ,and when i push the trunk
button from inside the car it beeps and the display says: Valet mode !!.
so back to the question above both my key fobs only worked when i put
them near the rear window and now STOPPED working?? Before this sh.. they worked from 50 meters distance
I cannot get the fobs working when i try to program them they just dont connect with the module in some way?? no beep on the console
What can i do ? any suggestions the Jaguar specialist says it has to come there to connect to a special Jaguar computer ??
I HATE THIS CAR IT DRIVES ME NUTS ,NOBODY KNOWS ANYTHING HOW TO FIX IT
As suggested earlier, open the remote up and give the contacts a good clean with electrical contact cleaner, and possibly give it a few runs over with a carbon/graphite pencil as well.
New batteries are a good start, but over time oils and grease and other crap get in under the contact points of the buttons and weaken the connection. This should help with the distance issue.
Holding the fob up to your ear is also a good party trick
DJ-Roy (03-31-2015)
BrentGardner
28
04-26-2024 03:08 AM
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
Ziggybeben
08-30-2015 02:09 PM
