Remote moves side mirrors
The remotes can be programed to preset seat, steering wheel and mirror positions.
What I mean is that one remote can be set for Driver A and the other for Driver B's settings.
I haven't set mine, and I dont know how to program them, but I saw in a Jaguar video that this can be done.
Jeffxj8
Jeffxj8
Jeffxj8
Jeffxj8
This can be repeated for position "2" and position "3" to suit two other possible drivers' preferences.
The following 2 users liked this post by Vauxi:
Carnival Kid (08-28-2020),
motorcarman (08-28-2020)
I can only think that it has something to do with the entry memory feature.
Try turning the feature off, using the selector on the steering column.
Or, with the feature on, try adjusting your seat/steering wheel/mirrors to positions that suit you and then activate memory one.
The position sensors are probably faulty.
Good luck with the diagnosis and repair if that is what you want.
Most customers declined the repair when I worked at the dealer years ago.
The 5 sensors are $300 each and the labor was 5 hours.
I would disable the relationship between the keyfob transmitters and the memory positions.
You can read the DTCs from the door modules and seat modules to get the code numbers but it will likely point to the sensors being faulty or non responsive.
More info for diagnosis.
Pristine97XK8Convertible
05-26-2020 09:57 AM
