remote programming
remote programming
i have a 1999 XJR. I have the instructions on how to program it. I opened the drivers door, I opened the boot, I put the key in the ignition and turned it to position 2(accessories on, engine off)(dashboard message panel is flashing door open, boot open), I hit the Valet switch 5 times....nothing. No chirping, no flasjing lights, nada. The troubleshooting guide says to 'check' the valet switch. Well, it works fine to lock the boot and goes into Valet mode, so I am assuming the valet switch is working just fine since it is doing what it it supposed to. How in the heck do I get it passed this point and into the 'programming mode'? Will the dashboard message center state 'in programming mode'?
I even tried the instructions for XJR's with no Valet switch (the flashing of the lights 4 times, etc) Nada.
Any other suggestions would be welcome!!!!
RE: remote programming
for xjr open door pull hi beam towards you then turn key to position 1 then let go of hibeam then pull it back 4 times then you will hear a chime.. then take key out and press unlock on every remote you wanna program .. you will hear chirps when unlock button is pressed then insert key and turn on.. then you will hear a confirmation chime.. then your done
zdrapec
09-25-2015 05:49 AM
