Removed fuse now radio is DEAD!
Well here is what happened. I have a 2000 XJ8 L. My father removed the fuses to the radio while thinking he was removing the fuse for the fuel pump. The car had to be jumped off because of a dead battery. Now there is no radio, no code, no nothin. So i went through every fuse in the car, all 4 fuse boxes. No blown fuses. I also replaced the ones for the radio, even if they looked fine. Still no radio. The CD player in the trunk has power, it will eject the CD holder. I need help. I listen to the radio all the time and its getting way to quiet. Thanks, J
Jaguars are not jump start friendly, especially when the battery is completely dead. If your headunit will not turn on and the fuses are good it probably fried.
In the future, it is better to disconnect the dead battery and use the other car or charger to charge it for a few minutes rather than jump starting the car directly.
Chances are you can find a replacement used headunit on ebay for not too much money.
If yes issue is with the radio ( I have a spare 1 I can sell you) if not, check wiring/fuse/etc
Guy-Pierre Boucher
09-16-2015 05:55 PM
