Removed and installed BPM, now have flashing red light on death on shifter area, help
So in trying to troubleshoot my crank but no run issue I disconnected my BPM to take some readings. Then I put it back and I get a rapidly flashing red light on the shifter area.
I forgot to unhook the battery when removing and installing the module.
I’ve searched here and on Google, but can’t find out what I did wrong or how to clear it. Any help would be much appreciated.
Thanks,
Mike
Thanks,
Mike
I am not sure if it will help but it sure won't hurt. Try a Hard Reset with the battery. Remove the ground cable and hold it against the positive cable for about a minute and then reconnect and see if it will clear the fault. You will have to reset windows and seats but it might solve the problem.
chillyphilly
10-28-2021 08:57 AM
