Removing front undercompartment cover?
I'm attempting to drain the coolant, and correct me if I'm wrong, but I have to remove the cover underneath first. There's about 8 star-headed screws, and I can't seem to budge one of them. Am I missing something here? I already broke the plastic on one. Surely (Shirley?) it can't be this hard!
Pulled mine off the other day for alternaor and water pump replacement. Use some WD40 on the stuck ones from inside and wait till it desolves enough to move. The plastic tabs on each side...I didn't realize how they worked till I yanked them out, pull the circular black piece out as far as it will go, then remove the rest. Mine had a zip-tie attaching the center back piece to the sway bar (keeps it from flapping...I guess), 2 holes drilled either side and the zip tie looping over the bar.
Chuck
Chuck
KarimPA
09-12-2015 08:15 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
